I assume the new brackets will be plug and play to the existing platform?
convex vx issues
Originally posted by ragboy View PostThat is my understanding, however, there is a modification that will need to be made to the part of the VX that mates with the back of the hull, which is why its a dealer issue.2013 Z3 - Electric blue and black
Tigé Junkie
- May 2013
- 920
- Central MN
I wonder how long it is going to take to get the dealers up to speed and get the correct brackets manufactured. I am starting to think that our northern season will be over by the time this gets taken care of. I am starting to think about removing the VX and ride without it. Sounds as if that might be the best option for all of us VX owners. Any thoughts on this?"I think I am pretty smart for an idiot"
Originally posted by Dandy View PostI wonder how long it is going to take to get the dealers up to speed and get the correct brackets manufactured. I am starting to think that our northern season will be over by the time this gets taken care of. I am starting to think about removing the VX and ride without it. Sounds as if that might be the best option for all of us VX owners. Any thoughts on this?
Sent from my iPhone using Tapatalk 22013 Z3 - Electric blue and black
Originally posted by ragboy View PostThat is my understanding, however, there is a modification that will need to be made to the part of the VX that mates with the back of the hull, which is why its a dealer issue.GO BIG!!
Originally posted by hycosurf View PostLooking at the vx, with altering the angle they would have to shave down the upright piece against the boat to accommodate the new angle. That's disappointing because my dealer is 3.5 hrs one way :/
The wake is fine without the VX on it. Been running without since June and the wake is great. The swim platform does not interfere at all.2016 Tige Z3, 2014 Tige Z3
Tigé Junkie
- May 2013
- 920
- Central MN
For you guys with the dealers so far away, I am very sorry for everything you will have to go through. I am frustrated with the dealer 1.5 hours away - can't imagine 7"I think I am pretty smart for an idiot"
Originally posted by Dandy View PostThanks for the feedback without the VX. Looks like the VX is getting dropped before the next time out...give us something to compare at least. As mnpracing said "what else can you do?"
For you guys with the dealers so far away, I am very sorry for everything you will have to go through. I am frustrated with the dealer 1.5 hours away - can't imagine 72016 Tige Z3, 2014 Tige Z3
Originally posted by mnpracing View PostSo you are saying that the actual VX piece has an incorrect angle on it, meaning once you replace the brackets, the VX won't line up correctly where it mates (or rather almost touches) the transom? So they have to modify the Vx itself, not just the brackets?
Originally posted by Duncan View PostAhhh, if only there was video ...
The wake without the VX is great, but I wouldn't give up on it, its really better with. And now that others are starting to get the right setup, they are confirming it only takes about 250-300 lbs of extra weight to achieve the same push/size as you did before the VX.
Chris Kinsey is testing with one for Wake the Desert, and they run in 8-10 feet of water which was a huge concern of mine. We have hit shallow water with the VX, and it didn't like it when we did the Delta shoot. But CK is dialing it in, and based on what he texted me last night, it is not coming off of his boat:
Originally posted by elite95Ok that's the best wave we have had to date! Adjustable toohttp://wake9.com/
Curiously, the VX on our Z1 measures just under 4", which is correct as I understand it... Unless we messed up the measurement, but it seemed pretty straight forward.
We are running pro ballast, with extra bags equivelant to the custom bags, and an additional 400lbs of lead (this made a huge difference). The wave is great, we are loving the boat, but taps provides no adjustment to it - as mentioned somewhere in this thread.
