I have 76 hours on my 2012 RZR and now have blown 2 fuses that control the Tige touch Medallion system. Blower works for 6-7 starts and blows using a 7 and 10 amp fuse. Blower works by removing the carpet access pannel that exposes the main breaker pannel where there are manual switches that can bypass the Medallian system. Blower works fine with manual switch. Blower yellow wire is tight going to the Medallion system, not touching anything. No obvious loose wires anywhere. Could the blower motor be causing the fuse to blow? Everything else works fine with Tige touch. Any suggestions?
I am at Norris Lake TN this week.
