Can't get my 04 24V past 3000 rpm. It starts chugging and drops to idle and then high idles at 2000 rpm. All I did was change the fuel filter.
boat dies after 3000 rpm
I would second the throttle position sensor and if that isn't it then it could be related to the variable valve timing system. I have been having some similar issues with my 6L and I think I have it narrowed down to the little actuator valve that controls the cam position. The part is cheap but the problem is that it is a major job to get to it in order to replace.
I would start by having it scanned and seeing if it is throwing any codes to point you in the right direction.
