Second bilge pump
    Depends on how well you know your ballast system but I've got 2 drain pumps that I can easily disconnect from my extra bags and throw them in the bilge to help pump out too. I also upgraded my factory bilge pump to a 1200 but I didn't add extra bilge pumps.
      That was always my problem with my factory pump, when full ballast water never made it to the pump, but for normal weight the factory works great. So I put this one as far back as I could for use while surfing. Not much room in a DDrive back there. Then I ran the thru hull up under the helm so its always out of the water no matter how I have the boat listed over. The factory thru hull will go under if you list to the starboard side, course I dont ride goofy so not a real problem there.
