Is they a way to tell if my RZ2 has a Catanium catalytic converter? I'm selling it and a person from Cali wants it. But they must have the converter.
2009 RZ2 W/ Catanium catalytic converter
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Very, very easy.
Open the engine compartment and look. The CAT exhaust components are silver and have enormous metal stickers that say "Catanium". The standard exhaust components are black and don't have the stickers.
Here is a photo (taken when I was installing our wet PSS shaft seal, hence the cut hose) that shows one side. You can see the other side in the upper right corner.
Hope this helps!
My 2009 RZ2 with Catanium 409 also has the silver exhaust components and big sticker.
Missing from WABoating's pic is the plastic engine cover stretching between the exhaust components -- that plastic cover might say Catanium also but I do not recall.
The option was many thousands of dollars so I doubt many boats outside of Cali have it. Though in Missouri, we got it because I wanted to scrub CO for surfing.
Only when sold as new, rightIf yours was originally destined for somewhere other then CA, your 09 may not have been fitted with a CAT motor, since CA was the first state to require it.
