Replacement touchpad for 2006 Accuset or 2007 Speed Set
    Just wondering if anyone knows of somewhere to find a replacement touchpad since apparently it's almost $1100 for a replacement from Tige. If you could install PP with the 2006 Marine power 5.7 it would only be $695 to change over.....almost double for something that has a limited lifespan, but is a necessity for good pulls for the normal driver.
    Maybe try a search. This has been covered extensively on the site. If I recall correctly the only answer is the $1100 replacement pad.
