Paid someone to winterize and RATS....Heater Core Bust
    For the first time since I owned our 2007 24ve I was too busy in the fall to winterize boat by myself. Paid the local marina to do it; talked to the guy, put down on the sheet that I had heater AND ballast pumps to winterize. Got there this spring; boat looked great, started right up....ran for a few minutes around the lake to test all systems, then put back on lift and noticed a lot of water. Checked for leaks and found major wetness under the heater core in front locker. The marina says they'll work it out with me: hopefully I can just get a new Core--lots of good posts here on the old Econoline Heater Core.
    Was a bugger to get out: Couldn't get the hoses off the barbs, one of the screws was stripped, had to cut the wires because they were wire-tied all the way to the switch. 15 minute job became a 90 minute job. Hopefully it will be a simple core replacement, re wire, and re-screw in....and rehose. In the meantime, I got a 5/8 to 5/8 brass barb and some fittings and just bypassed the old core.
    Impeller Change
    I also changed the impeller by myself for the first time. Was easier than I thought, only because I had the Jabsco Impeller Puller. It was like dismantling a bomb; had to reach around from the Starbord side, using the 5/16th nut driver, careful to not drop the screws. I don't know how you would get out the impeller without that tool. It was a hassle to get the new impeller in, even with the lube--but kept working it and finally settled in properly. Old impeller looked good so am keeping it for an emergency spare & keeping the puller on the boat in my tool kit.
    The only Ah-Ha learning moment; next time I'll make sure to look at the orientation of the cover when I take it out to make it easy to put back on. the screws have a different pattern. I used the grease to get the gasket to stick on the cover before replacing/re-screwing. I checked after I did and had some water spraying out, so I shut down engine and cranked down on the screws a bit more.... now all good.
    Lastly, I'm replacing the gas shocks that hold up the engine cover. Failed a few years ago--i used to just put a vice grip to keep it in UP position. Ordered replacements from Ameritool---maybe could have done cheaper with steel, but I did the stainless steel ones. Heck-I think they'll fail before they rust.
    Starting the year with 321 hours on the engine, looking forward to adding many more hours in 2013.
    Yep. That's toast. You should be good now.
