Well that throws out my guess on the starter and connections. Do you have jumper cables to do a quick test vs pulling batts out?
If it is hydro locking on you, water will drain into the crankcase with time as motor sits, releasing the motor to crank a few times until the cylinder starts to fill again. This increase compression to a point where the starter turns slowly until it fills enough and cant turn the motor anymore which can mimic a weak battery.
