I have a hose that is blocked off on one end and the other end seems to be connected to the bottom of the engine oil pan. What is it for? And do I need it?
Random hose
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Sounds like the standard oil drain hose. Theoretically you can stick it out through the transom drain hole to drain the engine oil by gravity, though my transom drain hole isn't large enough to pass the hose or its fitting. But by far the best approach is to connect that hose to a vacuum fluid extractor like the MityVac 7400, which will turn oil changes from a lengthy, messy chore to a five minute pleasure.
The gravity hoses work but seem to take hours to drain when the oil is cold. On my D-drive I just pop the hose out and let it drain all night and fill it back up in the morning. Makes for an easy clean oil change on that style of hull. But its a lot harder to get the hose out on a v-drive if it even fits out the hole like WA was saying, so pump probably your best bet. Alot of places also sell a little 12volt pump that works decent.
