This weekend I pulled off my old 537 and installed the new 1631. I then noticed that the old prop (been running it around 2 years) had probably 5-10 small discolored spots. Looking closer at them, I realized that in the center of each discolored area is a little pit in the metal. Since I have an even older 537 that came new on the boat and was run for a couple years, I looked at it but could not see any of these little spots.
Does anyone know what these might be? Our boat is stored on a lift in the summer, so I doubt that it came from corrosion due to water or galvanic action. From the appearance, I was thinking maybe they are inclusions of some sort from casting. Thoughts?
Finally - is there any reason to be concerned using this prop again? We have been using it for two years, so I would think the likelihood of a failure is low, but wanted to feel out the group for opinions. Sorry for the low quality pics, and thanks for any input.
