Just took out the boat to see if everything was working with the new ballast. I have the rule pumps running. There are a few leaks around 1 check valve and a few others around the drain pumps and by the drain thru hole. I can't seem to tighten the clamps tight enough without stripping them and then I've tried using 2 clamps and they still slide around. Ideas? Thoughts?
Thanks!
Thanks!
