SeaDek walk through pads installed on a 11 22ve
      Looks sweet! you get it directly from sea deck?
        yes I did.
          Looks good and I'm sure you will enjoy it. I have been wanting to SeaDek mine. Maybe next year.
            looks good!
              Looks great. How much???
                Is that a different color than you swim step pad? Someone said you need to sand the texture underneath the pad so it will stick, did you do that?
                  Looks good man!
                    It cost 250 dollars. It is a lighter shade of gray but matches the interior color better. I didn't sand down the texture. It stuck really well.
                      I did my old 22ve and then my RZ 2 without sanding and both have held up with no issues.
                        This looks great. I am waiting on my shipment of the same pieces for our 2009 RZ2.
                          Looks great, Justin! Maybe I should order that for my boat with my pimp my Tige prize that I won...
                            The price on a full set of transom and walk through pads is less than you might think because it all fits on one sheet. (A pair of pads for the bow traction spots on our RZ2 also fit on that sheet). Ours were a bit more as we went with the faux teak.
                              Looks great! I am thinking of doing the same project on my 2009 22Ve. Did you order the template kit from them and have them custom make the pads or cut them out of a sheet yourself?
