I just had Perfect Pass Wakeboard Pro installed a few days ago on my '98 21i. I have not been on the water yet but noticed that the throttle is very stiff now especially the first few inches out of neutral. Is this normal/common???
Perfect Pass
can you guys tell me where the pick up sensor is for your perfect pass. Mine has a very hard time keeping the boat constant at about 19-21 mph, as well as in turns, just wondering if they put it in the wrong spot. I have heard that your supposed to mount it in front of the fins, but mine is mounted on the side of the engine.
Thanks in advance.
DomOriginally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Mine is mounted on the bottom of the boat (hull) near the fins. I have a 1999 2200V. I had the wakeboard pro installed 2 yrs ago when the original PP went out. The people at perfect pass gave me a great deal on the upgrade to the wakeboard pro. I had it installed at a local shop ( I was to scared to drill a hole in my boat). I have nothing but good things to say about the wakeboard pro and perfect pass.
Also, you may want to check your troubleshooting guide for your specific symptoms. There's usually a simple explanation (I don't have mine in front of me now), but from what I recall, you should check the auto-tension mechanism installed on the trottle control by your engine. If your throttle cable is sticking, then it may be having trouble adjusting the throttle. (the manual gives you some pretty easy instructions for determining if this is the case).
I have the PP Wakeboard Pro and it was installed last year (I think it's Version 6.5). I love it.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Paddle-wheel replacement
Hi all,
I've ordered a new (PP) paddle wheel kit and have not replaced it yet for my 21V Riders. Any suggestions or info I should know or do before I install it? I broke the paddle wheel on my hoist, so I have to replace it. Received the new one (paddle-wheel & o-rings) but it did not come w/instructions. I'm sure I can figure it out, but if anyone has done it, I'd appreciate the advice. Thanks.....Love your little ones!
Hi all,
