Tower completed!!
    Tower completed!!
    I had posted a thread before the site went down discussing towers, brands, thoughts, etc... Well with a new addition on the way due in October, I opted for the less expensive Aerial Assuault tower. To my surprise, the quality was better than expected. Although, It did take about a month to get in stock, I did get it in great shape and packaging. I only ran into one problem installing the tower, cross threading a joint (which I re-tapped and bolted with a larger bolt). Passing the wires through was tricky but thanks to some of the threads on here, I was able to use the fishing line and vaccum trick! Well, here are the pics, can wait to show the final product once seats and LED's are in!
    Looks good! Time to get it out for a test pull.
      Going out tomorrow, Ill repost with the outcome, Ill also try to shoot a vid of tower pulling someone. Seems to be MUCH stronger than the metacrap tower I was working with..
        Just make sure you lock tight the little set screws as they come loose often and strip the heads out! Tower looks awesome on your boat
          Congrats. Looks nice. It's certainly a huge improvement over the Metcrap.
            Looks good. Has similar lines as the Tige e-series tower but the main cross bar looks sturdier and the black finish looks great against the yellow boat. A great improvement from the Metacrap tower. Good luck and enjoy.
            I am surprised the fishing line and vacuum worked. I have seen many comments that people could not get that to work when I changed my tower so I had the factory pre-drill and fish wires need. It cost me I think $35 when I had it done in 08.
