With the new bluetooth capability, are there any Tige' owners out there using the Perfect Pull app? Looks pretty neat and am curious to hear some feedback on it.
Any Tige owners use the Perfect Pull App?
i downloaded it right before we went out to the Mead event back in Sept, but the dealer woudnt let nayone near the boat. But, I think they have since figured out they dont sell that wayMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
My dealer was telling me about it, but my concern is if the app allows you to configure exact models. Since some models have a single bow sac vs. two (one for each side). If you can customize to the specific setup of your boat then this app seems like it would be awesome!
Also, I guess this is a little off topic, but for example when you have presets on your Tige' touch and you are switching from one to another, does the pump automatically shut off once it's done emptying that side?
My understanding of all the full vs. empty tank gauges are based upon a timer on the pump. The times are measured to fill and the computer is told that is how long it takes. You see the tank being full. Same goes for empty. Not a perfect system as pumps wear out, malfunction, check valves don't work, etc.2007 RZ2 Marine power 340hp Custom ballast
Tundra Crewmax 5.7L
Originally posted by Ktm.Moto View PostMy dealer was telling me about it, but my concern is if the app allows you to configure exact models. Since some models have a single bow sac vs. two (one for each side). If you can customize to the specific setup of your boat then this app seems like it would be awesome!
Originally posted by Ktm.Moto View PostNot all 2013's have two sacs in the bow, it depends on the ballast system on the boat. The surf ballast one single u-shaped bag in the front and the pro has two separate bags, one on each side of the bow....I believe, but please correct me if I'm wrong.
I am only assuming that on our 2013 RZR we have two ballast bags up front. We have separate controls on Tige Touch for each side and you can hear the different pumps work independently of each other for filling and draining.
The perfect pull app seems to have detected the same settings for our Tige Touch as when I edit a profile on my phone I get the four different ballast levels just like on our Tige Touch. Vs. the example that comes with the boat and only has the three ballast levels to adjust.
BTW We have the Surf Ballast on our 2013 RZR.2013 RZR w/ConvexVX
http://www.surfsupws.com http://facebook.com/surfsupwatersports
Originally posted by zroutt View PostI am only assuming that on our 2013 RZR we have two ballast bags up front. We have separate controls on Tige Touch for each side and you can hear the different pumps work independently of each other for filling and draining.
You could probably check easily by pulling the bow cushion and looking through the large hole there.
Either way, I don't think if really matters as its either a 400lb U or 2) 200lb sacs.
I did hear awhile back that they were doing hard tanks in the bow on 2013's but I've never confirmed. It seems like they could do a couple hard tanks in the bow and get anywhere from 250-350 per side if they used all the space.
It may be a capacity issue though on the 20' boats.
Originally posted by houstonshark View PostMy 2012 RZR has 2 fill and 2 drain pumps but a single U shaped, 400lb bag with the Surf Ballast. You can fill or drain either side in the Surf L or Surf R presets.
It may be a capacity issue though on the 20' boats.2013 RZR w/ConvexVX
