Looking for sub advice for RZR
Originally posted by NICKYPOO View PostFWIW, I have been running the same 10" RE re series sub for 10 years. It still hits just as hard as new and still sounds great.
Originally posted by Bruizza View PostI have had a syn 2 hooked to both subs and the RE is still the better sub IMO. Both subs are in ported enclosures built to the manf. specs.
It's a just as vintage Rockford Fosgate Punch 200.2, bridged. The sub is in a 1cf sealed box stuffed with polyfil. It's very basic. I think I have less than $250 in bass. It sounds plenty respectable, it will ripple the water if turned up and has been bulletproof for 10 years now. It should be noted that I'm not a big stereo guy. I don't even run tower speakers. I keep my music in my boat.You'll get your chance, smart guy.
Originally posted by barry1me View PostWhat amp are you running?
How do you like the syn 2 with this amp?
Originally posted by barry1me View PostI like the location under the dash area. Whats the advantage of the downfing sub?Ain't no 1/2 steppin'
Originally posted by Duncan View PostNice enclosure. Are those front ports?
Does anyone know of other pics of sealed and ported after market sub enclosures (ideally on an RZ2)?
Originally posted by barry1me View PostGreat info guys. For the newb I am what is sq and SPL? What will a wet sound 12inch sub cost and what amp should I push it with? I think I currently have a syn6? Pushing the rev 8s and I think a syn 2 pushing the 4 smaller wetsound speakers in the boat.
Definition: SPL
SPL refers to the sound pressure level you experience as a listener--in other words, how loud is the noise coming out of the subwoofer? Measured in decibels, the SPL is affected by the decibel rating of the system speakers, wattage of the amplifier, speaker placement and position, and number of speakers in the stereo or home theater system. SPL is a quantifiable measurement; you can buy an SPL meter at specialty electronics stores if you want to measure your subwoofer's output. If you're after a high-SPL subwoofer, look for one whose drivers have a high power rating and high volume displacement.
Definition: SQ
SQ refers to the sound quality of the noise produced by the subwoofer. There is no hard-and-fast way to measure SQ; this largely depends on the listener's preference. The way we perceive sound quality can be affected by a number of things, including the subwoofer's placement in a car or a room, the shape of the room and absorbing materials placed near the subwoofer (fabric, carpet, curtains, etc.). At its most basic level, a good subwoofer should reproduce the desired frequency range at plus or minus 3 decibels. Individual rooms can have an effect of plus or minus 15 decibels. As a result, sound quality can be influenced as much by subwoofer location as by the human ear's perception of sound.
If you are not a bass-head, then with only 4 in-boats driven @ 60W each, I wouldnt worry about going with a 12" driving @ 600W unless you want. A nice 10" 4 ohm DVC will do what you seem to be looking for. Now, on the flip side, with good tuning and use of the optional sub remote level control, you can really dial back the output, so going with a moderate 12 receiving the full 600 available watts is a pro. Deeper bass due to the extra surface are, plenty of head-room with 600w, so you will not be cranking the crap out of trying to get more output.
The next thing to decide on is if you want to tackle the task of contracting an enclosure or keep it simple and go with an infinite-baffle (free air) configuration like Tige does OEM with the XS-10fa. This just requires finding the OEM spot and cutting the hole out, mount the sub and connect the sub wires which are probably already there. Done right, an IB sub can and will offer the needed bass to fill in those missing notes. Good thing is, the Tige boats are one of the best for doing an IB sub as they have a solid bulkhead under the helm that offer complete front/rear isolation and then a large comportment to act as the enclosure. Down side is, there are not many 4 ohm DVC IB subs out there, and a not many single 4 ohm coil 10's that will handle 600W. Thats a ton of power to a sub with now small enclosure for added dampening. I do not know how these are coming from Tige now that Wet Sounds only offers the 4 ohm SVC 10fa. Wiring the 4 ohm SVC to only 1 chnl nets 155W. Thats a little IMO, but certainly doable.
If you are up to building an enclosure, it will pay dividends in terms of sound quality and output. It also widens the options greatly. A sub in an enclosure will always trump an IB.
If you decide to go the enclosure route, you need to make sure you get the horse before the cart. The boat is going to dictate the gross external dimension of the enclosure. This is what you have to work within. based on that, you need to then choose a sub that will compliment the available size, or smaller. You then need to take the available amp power into consideration. This will further steer you to a particular woofer. price wise, theres typically not a huge difference in cost between a 10 and a 12 within the same series or model. So dont let that be a factor. A 12" will typically require a little more box volume, translated to external dimension, then a 10. So let the available space make that decision. You also need to decide whether you want to go with a simple, more forgiving sealed enclosure or go with a more complex ported. ported leaves a smaller margin of error, so the available gross dimensions will need to include the port structure in the box, but the space taken up by the port structure is not part of the subs recommend volume. So a ported enclosure will require a larger enclosure over all, then a sealed setup. This could be a deciding factor between a 10 in a ported or a 12 in a sealed as an example.
Dont get bogged down in a brand name. there are plenty of good subs out there. The best one is the one thats done right.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View Posthere a couple of good explanations:
If your boat has the Syn-6, then that's whats driving the in-boats and can driver either a single 4 ohm sub using the open chnls 5 and 6 with 600 available watts, or 1 or 2 2 ohm subs with an available 300W eac on chnls 5 and 6. So, the Syn-6 can power a mild 4 ohm DVC 10 wired in parallel and wired to chnl 6 or 2 of them and use both chnls, or a moderate 2 ohm DVC wired in series or a single 4 ohm 12" wired across chnls 5/6. So you have a couple of options.
http://www.sonicelectronix.com/item_...o-SXX12D2.html
with possibly this amp
http://www.sonicelectronix.com/item_...-R1200-1D.html
I deffinatly want some sort of sealed box. Have to determine if ported is the trick or not.
Originally posted by barry1me View PostI honestly am not sure if I have the 6 or the 4 syn model amp. I will find out as soon as boat gets out of storage. I have been looking at the RE audio stuff I hear its pretty decent.
I deffinatly want some sort of sealed box. Have to determine if ported is the trick or not.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostRE's are great subs, but that doesnt mean the SXX is the right one for you. You need to get the horse before the cart. If your boat does indeed have a Syn-6, you have 600 available watts sitting there, so you may not need to even buy an amp. Also, the SXX on a 1200W amp is not just going to fill in those missing bass notes, its gonna ripple the water. Also, some subs are best suited for sealed enclosures and some are better suited for ported, based on their T/S parameters. As noted, the boat is going to dictate a lot.
