That's understandable. That Aerial isn't going to fit like you have it shown. The rear mounts would have to go to the sides of the hull. They are also China made and if you have to send anything back, it'll be two weeks before you get a replacement. They will not ship anything until they get the offending part back. Had to do that on a friend's boat. The upper tube was bent (super thin tubing) when we took it out of the box and the tower would not go together. It sat there half done for two weeks.
The spring updates had began
I knew the fit on the screen shots, but gives me an idea of what it looks like. Scale is off a bit too. Mount points are longer on the aerial than it shows.
China makes me want to order the H2O plus if I had a problem its an easy call or at most if I needed it quickly a 4 hr total drive to get new parts.
Originally posted by dreamintige' View PostWe were an Arial dealer. No more. Their customer service is the absolute worst. So bad that my parts accessory supplier stopped carrying them in their catalogs.
Originally posted by Ruger761 View PostIve never been crazy on the look of the front 2 bars on the monsters. They just turn in too quickly killing view out of front.
The only thing Ive heard on Aerial is they sometimes are not the strongest. Have you had any dealings with them?Attached Files
Originally posted by LTtige22v View PostI had an aerial on my last boat. It was great the only thing I did to it was has the joints where the tower tubes meet the inserts welded up by a local shop made the tower super tight.
I think the H2O is going to be a great tower. I'll add comments/pics after the install. Then we'll also see how well they preform. The fun part is when you put a tape measure to the boat and see how nothing is ever perfect side to side. The end of the window frame is off about 1" side to side from the bow. So its almost throw the tape out the window make the tower match up with the boat side to side.
Originally posted by Ruger761 View PostThat doesnt shock me after reading the install instructions.
I think the H2O is going to be a great tower. I'll add comments/pics after the install. Then we'll also see how well they preform. The fun part is when you put a tape measure to the boat and see how nothing is ever perfect side to side. The end of the window frame is off about 1" side to side from the bow. So its almost throw the tape out the window make the tower match up with the boat side to side.You'll get your chance, smart guy.
