Does anyone know if i can buy new forks for the Tige alpha z swivel racks to hold surf boards? I have done a few searches but didn't come up with anything. Someone said Samson was going to make them but i can't find them on their website. Maybe i'll give them a call.
surf forks for tige racks?
samson does a full replacement for the tige racks that you can get in a surf/surf or surf/board setup. not sure if the tines are interchangable. they were fairly spendy at $1200/pr, but cheaper than tige's racks.
I'm hoping to sew in surfpockets as bmoor suggested above. they are handy if you have custom boards that can dent easily. dealer told me total cost for surf pockets was in the $200 range for 2 on the top. might try that way first..2012 22ve.. RIP 4/17
2014 Z3.. Surf away
Surf Forks
I have some on my boat. I bought them a couple years ago from a guy on this site. They work well. I believe that they are made by bullet. The ones in this photo were on ebay -- http://www.ebay.com/itm/KRYPT-DOUBLE...-/330823036800. They look just like mine. Mine bolted directly to the existing tige swivel rack on my 2007 with the z tower (not to be confused with the current alpha z tower). I didn't use the mounting plate, the fork holes matched up perfectly with my tower rack. I'd try to find some that bolt right on.Attached Files2007 RZ2 Marine power 340hp Custom ballast
Tundra Crewmax 5.7L
Originally posted by bigskymudflaps View PostI have some on my boat. I bought them a couple years ago from a guy on this site. They work well. I believe that they are made by bullet. The ones in this photo were on ebay -- http://www.ebay.com/itm/KRYPT-DOUBLE...-/330823036800. They look just like mine. Mine bolted directly to the existing tige swivel rack on my 2007 with the z tower (not to be confused with the current alpha z tower). I didn't use the mounting plate, the fork holes matched up perfectly with my tower rack. I'd try to find some that bolt right on.
I recommend Samson racks..top quality and fit perfect.
http://samsonsports.com/tower-access...ge-boardracks/Nick
Dayton, Ohio
I have a 2004 24ve with the E series tower. I’ve been struggling to find new forks to bolt to my existing wives plate system but the bolt pattern tor the forks/tines spacing on mine is 1 3/4” between the two bolts. I have a few emails out to sellers/shops with high hopes to find something that will work.
