I'm changing the filters and fluids in my '03 22V (350 MAG) for the first time on my own. After browsing the forums I thought I was armed with the info needed for a quick off season afternoon of maintenance. I'm near frustration with my in-line fuel filter and small leaks at the fittings.
I decided to make the switch from expensive Mercruiser filters to WIX filters. I bought a WIX #33481 for my in-line fuel filter conversion. The WIX is threaded differently than the OEM Mercruiser as pointed out here on the boards. My problem is that I can't find a high pressure threaded fitting to barb connection.
For those who have made the switch from Mercruiser, any luck finding tapered, threaded fittings to connect the fuel lines back to the WIX filter? Do you have a part number or link?
