Ok, it seems that everyone is receiving, or about to receive their LED ring orders and may have some questions about hoe to assemble the LED strip and ring.
For the in-boats and cup holder: With the speaker or c/h flipped over, take an alcohol pad or similar and wipe down the basket all the way around just above the mounting flange. Do the same with the c/h just above the lip.
peel the adhesive back about an inch to start. Apply the end of the strip with light pressure to seat the adhesive. Then work your way around peeling the paper off the strip as you go.
For the speakers, I like to start and end the strip where the speaker terminals are. On your cup holder holes, you may need to notch the hole to allow room for the harness. The is almost a must with the RGB strips as there's 4 wires. a .25 rat tail file works for both holes in plastic panels and fiberglass. Try to locate the cup holder harness in the back, so notch there if its required.
For Gcombe thats doing some Pro60 rings, here is a link: http://www.wetsounds.com/media/produ...stallation.pdf
