SeaDek Tige 22Ve
    SeaDek Tige 22Ve
    Wasn't able to find much on this so figured I would share this video for those considering SeaDek's custom decking purchase and install. These guys are on top of their game to say the least. Very pleased with the purchase and the install was effortless.
    http://youtu.be/i2u43o8DPIE
    Looks good. Did you do the swim platform as well?
      Here you go
        Thanks Skippa! I did not do the swim platform, at least not yet. Mine is still in good condition plus I may be doing some modifications on it soon. That being said, I just had a friend here in Austin with the same boat fabricate and install his version of the "surfgate". We should get it in the water this weekend and test it out. I'll be sure to get some video and let you know how it turns out since you share the same boat
          That will be cool to see.
            That looks awesome man! Now I have more to add to my winter mod and order list.
              Thanks halfwatt. I actually took her out surfing today with a couple friends and both of them commented on it. Not only on how much it dressed up the transom, but that it actually kept them from slipping on a couple occasions.
                Just a heads up, IIRC the '06 is slightly different than the '07 patterns.
                  Fortunately this isn't a pre-cut pattern. They'll send you a "template kit" which consist of a sheet of Mylar plastic and a black marker. This allows you to trace the areas you want custom padding cut for per your boat/specs. Check it out: http://www.seadek.com/c-9-template-kits.aspx
                    They do have some of the templates stored. For example if they don't have yours then they might use your template to now create a pre cut pattern.
                      I wonder if they saved your pattern?
                        I'm sure they still have it on file since I just placed the order. If not, and you are comfortable with using my designs and template, here you go........
                          Awesome was gonna ask if you had the details so i could pass them on to my buddy who wants to do this mod. looks great!
                          FairTax.org
                            Thanks for posting that I will order in the spring.
                              I was looking at doing the samething and now after seeing it I'm totally doing it. Thanks for the share.
                              "Riding the Wake of Life"
