That is one of the cool things about the Mendonesia Half Moon board. It pumps and has the drive of the SS, but it also has the down the line speed. Really fun board.
Hazen Passion Pop sequence behind Z3 with VX
No, read them all. The only guys that said that was 2 goofy guys, and the goofy side has an issue, that tige is fixing, and I think it is a simple fix.
Also, you can ask Majestic, he was one of the guys that said he liked it before. We dialed it in a little better and had him out again, and that changed, I think, but I will let him tell you.
The problem on the goofy side, until that issue is fixed, its more touchy and hard to find that sweet spot. On the regular side, its super easy to find. I think Dave Rusch (tahoe surfer) was the other guy that said that, and I also had them out again, but they are welcome to respond.
There is no doubt in my mind it is better, and Chase definitely felt so also. Tige sent me the device on our boat, along with our old deck and mud flap. They knew that if it didn't work, I would take it off, go back to the way it was and just not say anything. After testing it, even though we are almost all goofy, we through the mud flap away, which was a lot of work to get right.http://wake9.com/
Originally posted by bspot View PostNot convinced on the convex vx just yet. Reading the boat reviews on wake 9 most guys are saying they liked it better before?
Originally posted by ragboy View PostNo, read them all. The only guys that said that was 2 goofy guys, and the goofy side has an issue, that tige is fixing, and I think it is a simple fix.
The reason it may seem a bit shorter or lack a bit of push on the goofy side is that to get rid of the mohawk, you have to list it over a bit more, maybe 2 degrees, and it shortens and takes a bit of push. We have now been able to work around that, but Tige is definitely making modifications to make it as easy on the goofy as it is on the regular to find that perfect shape, push, lip, etc. If you see how the water flows through it I think you would see how this should be a relatively easy thing to fix, but just needed to be thoroughly tested by folks like us that really use it.http://wake9.com/
Originally posted by duffymahoney View PostChase's pump is so so strong. That's why his shred stixx customs seem sluggish to other people. But when you really pump them they are a rocket ship. I bet money that his new liquid board is the same way.Originally posted by ragboy View PostHe was struggling a bit first 2 days, still great, but not his best. So he was playing with his fins and asked RJ if he could borrow a couple fins and chase shaved down a couple of canards from his Soulcraft Jetty and chase made them work in his FCS boxes, and so he rode the last day as a Twinzer setup, not a quad, or six fin. Chase said he liked that setup, but not sure how much that affected the drive, had to reduce it a good deal, I would think.Originally posted by Timmy! View PostThat's what I didn't like about it. You are always working on that board but if you pump it, it goes like hell!
Thanks for the information. That helps explain the board.
Fast forward 2 weeks and I came back down to slam the boat and see how the wave was. It was huge and there was no lack of push for sure but the curl had so much mass when my back leg would get hit by the curl I couldn't catch back up. Later we emptied the 1100 pound jumbo sack and the wave was the best ever. There still was some wash being thrown but I know that will get fixed soon and I can't wait to test it again.
If you look at the way it mounts onto our deck:
IMG_8551 by wake9, on Flickr
Its really just holes in the swim deck brackets that the device mounts to. Makes me think, and this is NOT official, that if you made one of these for the 2012 RZ2, you could buy it and just drill the holes in the 2009 (or whatever) RZ2 swim deck. Assuming the bracket mounts are in the same place or same width apart.http://wake9.com/
