Originally posted by talltigeguy
View Post
Looking for dead 24Ve
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by boatwakes View Post12MPG, our tige now burns 4.5gph at worst (that's with 89 octane, it burns 3.2gph with 87)
MooseX, NICE! Please keep me posted on that one. WA, I did the comarisons the first time we went to Lake Mead because all they have is 89. We showed up with a full tank of 87, ran 8 hours filled up and kept an eye on the mpg. It tanked and my driving style didn't change so we took note and it did the same thing after the next 3 tanks we put through it. The computer has to advance the timing with higher octane and when it's programmed for 87 mileage will go down with higher octane. The new higher horsepower 6.0 and 6.2 engines I'm sure have an octane requirement that's higher but wither way diesel is better.Fixing everyone elses boat just so I can use mine...
Originally posted by WABoating View PostWhy would octane make that much difference in fuel consumption? From what I understand (which is very little), octane increases the flash point of the fuel so it won't ignite due to pressure.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by shawndoggy View PostThat's exactly right. Higher octane fuel is less volatile, so you can advance timing farther without premature detonation.
More to the point: Why would advancing the timing reduce the mileage? Wouldn't the same amount of fuel be injected, regardless of when the spark is told to fire?
Just trying to understand....
Tigé Jedi
- Jul 2010
- 4302
- TN USA
OK, but advancing the timing - by itself - shouldn't change how much fuel is consumed, right? Fuel consumption is controlled by injector pulse width. Timing is a question of when the spark occurs relative to crankshaft rotation.
Hopefully someone will educate us....
Originally posted by WABoating View PostOK, but advancing the timing - by itself - shouldn't change how much fuel is consumed, right? Fuel consumption is controlled by injector pulse width. Timing is a question of when the spark occurs relative to crankshaft rotation.
Also lower octane will explode at lower compression and start the power band earlyer , injector puslse width will change based on map signal change if the pulses in the intake are changing speed, thats why its called a speed density system, however the test would need to be same condition , air temp , baro , etc.
