Or even just have a form fitted mat that would go in the compartments the a weather-tech floor mat use in automobiles.
Why Carpet?
Originally posted by bspot View PostOr even just have a form fitted mat that would go in the compartments the a weather-tech floor mat use in automobiles.
Originally posted by Iwndr View PostMy Sis's 2010 VLX are smooth walled rear compartments on the engine side and floor.
I would like to see all the carpet go away, but the price will go up because like Bspot says, it is cheaper to cover flaws then to finish them
Originally posted by JreisRZR View PostWhy not spray it with rhino liner or a rubberized spray type material? I can't imagine the price difference would be huge by the time you eliminate extra labor
Now that I think about it, it should be pretty easy at the factory to mask off and spray the storage compartment floors with a Line X type of material, prior to carpet. The problem is that you'd have to have some sort of mat to put down on top of it to keep stuff from sliding around.
Originally posted by JreisRZR View PostWhy not spray it with rhino liner or a rubberized spray type material? I can't imagine the price difference would be huge by the time you eliminate extra labor2011 Tigé RZ4
www.re-viveupholstery.com
Originally posted by JreisRZR View PostWhy not spray it with rhino liner or a rubberized spray type material? I can't imagine the price difference would be huge by the time you eliminate extra laborFriends don't let friends POWERTURN
Originally posted by Iwndr View PostThe VLX had black panels lining the compartments on the floor and engine side,the Hull side was carpeted I think they were plastic but not positive about it.
Originally posted by Coop View PostMy bad. Thanks. So, do they have seadek in the lockers?
