I bought mine from www.SKIDIM.com, ask for Vince.
They are located about 20 minutes from the PCM plant here in South Carolina, USA. PCM and Marine Power both use the same GM block that comes from the factory with that throttle body.
I did the same exact thing you did. Throttle body and gasket should run about $250 US plus shipping.
I read your post AFTER I had done it, have emailed them so hopefully they will come back today
It's a nightmare out here in middle east trying to get parts
Do you know the part number?
