Wet Sounds New Z3 demo boat
almost done with the rev 410 prototype. working on the stereo now but will be a while until we get it all taken apart and started.
I will get pics as soon as we have something to show.
Sea Dek teak floor and swim dek is being made right now. So that should work well with the boat and look we are going for.
Tim
Wet Sounds
we have designed a adapter bracket that allows you to mount a pair of REV 410 to the Alpha Z tower. Using the factory top mounts. We made it so it is wider and bolts to the factory mounts as well as have a clamp top over the tower to distribute the weight of the speaker over a wider area.
Tim
Wet Sounds
Tim, are you putting SeaDek teak in the cabin rather than the carpet? I'm doing the same on my 13 Z3, it would have been finishing up in production right around the time you picked your boat up. Maybe you seen the boat, it was the solid pearl metallic black with 4 white Rev 10's.
I really like the interior look of the new G's from Nautique and was the look I wa hoping to get with the faux teak for the Z3.
Love the look of your Z3, it looked great without the wrap as well.
Originally posted by wetsounds1 View Postwe have designed a adapter bracket that allows you to mount a pair of REV 410 to the Alpha Z tower. Using the factory top mounts. We made it so it is wider and bolts to the factory mounts as well as have a clamp top over the tower to distribute the weight of the speaker over a wider area.
Tim
Wet Sounds
