It has begun. We are building our new demo boat. Z3 this time. This will be our third Tige demo boat. RZ4, RZ2 and now Z3.
As always we are going to push the envelope on design. Cant wait to share the finished project.
Follow the thread and I will post some build pics as we go.
I want to give a big thanks to the guys at Tige! They have been awesome letting us do some crazy custom stuff.
And for the first time i know of anywhere, build a boat around a sub box! They have done a lot of work to get this crazy idea done. We designed an enclosure for 4-XS-XXX V2 subwoofers. The design uses the hull of the boat as part of the enclosure. We glassed in panels into the sides of the hulls and the top and back of the enclosure. So all 4 woofers fire out of the same plane. The side firing ports fire into a sort of "wave guide" glassed into the hull so everything loads out of the front. The enclosure is made of 3/4 inch marine grade birch that has been coated and then sprayed with resin before being glassed into the hull. The front face is double wall as is the top and back.
Each XXX V2 will have a new Sinister SD2 for 1250x1 per woofer. So 5000 watts just on the subs.
As for the rest of the system and build. Stay tuned.
Tim
Wet Sounds
Tim
Wet Sounds
