Ok, so as everyone knows with Tige boats, the bilge water sits about midpoint of the hull renedering the bilge pump at the back essentially useless.
After removing the floor to expose the gas tank it appears that the gas tank has a couple of access holes in it, and the deepest point of the bilge water is underneath the forward access hole (see attached photo).
The hole is 3" in diameter and about 8" deep.
I would like to install a bilge pump inside that forward access hole. This would really help emptying the boat when it takes on rain water in the driveway as well.
Does anyone know where a narrow bilge pump, or perhaps a bilge pump that pumps out the top directly could be purchased? All of the standard pumps like Attwood and Rule are too wide when you attach fittings to the output side of the pump.
