Impeller replacement
    I need to replace the impeller in my 2004 22v.
    Does anyone know what type I need? From what I have seen online I should be able to replace it myself, correct?
    I was thinking of following this guide
    http://www.tigeowners.com/impeller.shtml
    The boat has a GM Vortec engine.
    Thanks
    Is it a Marine Power, Mercuiser, or PCM?
      not sure how to tell
      Its a GM Vortec engine...how do I tell which type I have?
        take a picture and show it
        From what you say I am guessing Marine Power but could be wrong.
          IIRC the older MP had a label of 335 HP
            The engine cowel will usually have sticker
              Impeller
              The engine is labeled GM Vortec 5.7L 335HP and has a Tige sitcker on it too. Im not at home right now to take a pic unfortunately ;(
              thanks again
