I just finished removing all the trim from my 98 PRE2002WT. Removing the trim from the bow area was a total pain. I had to have my skinny armed 10 year old reach up to undo the nuts holding the trim to the hull. There are a total of six bolts fastening the trim to the bow. I can easily access two. The remaining four are a nightmare. Anyone know a better way to reach these? Putting the trim back on is not going to be fun in this area. Will try to attach a picture later.
Vinyl replacement question
Yeah. I'm not so lucky. This photo is a bit grainy (took at dusk), but you can see where the six bolts are located. With the minimal space along the floor and the depth of the wooden structure, I can't figure out how to get more than a 10 year old sized arm in there. The rest was pretty easy to take out. Not looking forward to putting this back in. I even tried pulling the nav lights with the faint hope I may be able to access a couple through there. Again, arm is too big.
Cut a 5" hole on each side to access those screws. Once the vinyl is complete, fill the hole with a pair of speakersMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
