I have read a number of threads here and seeing conflicting answers. So my direct question, on my 2001 2300V Limited, should my prop, prop shaft and rudder all be in line in the center of the boat. It was this way when I got it and it drove strait. I know I hit a stump under power recently, and now the boat pulls to the right. Closer inspection last night and the nut on the end of the prop shaft is about 1 inch to the left of center or rudder, driving the boat to the right. I have seen lots of posts that this is normal for prop shaft removal, but other posts boast that tige should be in the center to give a more balanced wake. My wake is much better on one side now where I believe it was more even when I got my boat April of this yr. My nearest dealer is a 3-4 hr pull, and I dont want to haul it in for them to tell me it is normal and designed to be there. No noise or vibrations, but if you look close the prop shaft hanger looks bent. The other question would be how bad would it be to swap out the prop shaft hanger? I am mechanical and think I could handle that.
Any comments greatly appreciated.
Skip
Skip
