So I emailed ACME for info on upgrading props. Sales rep says the 1579 is the upgrade for me on my RZ2.
I ask about the Acme 1273/1235....he replies....
they are 1" larger in diameter...it takes more energy/HP to spin a bigger prop...you would get even less low end performance than your Acme 537...plus there could be a clearance issue between the prop and the hull...
ok...now Im confused!
