Alpha Z Update
    Alpha Z Update
    Well as some of you asked its coming.. Samson is making forks for your swivel racks that will hold two wakeboards and a surf board in the middle.. Should be here soon!
    My bro has these on his MB. They are ok racks at best. The way the bungee is designed kind of sucks. It's in the middle of the rack and has a very small hooking point. Bards move around all the time. Also if you check the MB forum you will see many complaints of the bottom board coming out if you actually out a surfboard in the middle. MB throws them in for free with all boats. So I am guessing Tige will charge $2,000 for a set of these.
      haha.. I dont think you can get em through Tige.. I was talking with samson and there just making them this fall. Tige likes there MIllion dollar clamp racks that Im sure they buy for 300 each!
        x2 on that.
        2011 Tigé RZ4
        www.re-viveupholstery.com
          Over three years ago, I went back and forth with Samson regarding this same thing (triple wake/surf/wake rack). He said he would fabricate me one but when I followed up (about one hundred times), the project never moved forward.
          Glad to see it is going somewhere. I will definitely be grabbing at least one, maybe a pair.
            Figures, I just got the surf pockets sewn into my bimini, didn't even pick it up yet, but of course that is much cheaper then new racks.
            Friends don't let friends POWERTURN
              Originally posted by Bruizza View Post
              My bro has these on his MB. [B]They are ok racks at best[/B]. The way the bungee is designed kind of sucks. It's in the middle of the rack and has a very small hooking point. Bards move around all the time. Also if you check the MB forum you will see many complaints of the bottom board coming out if you actually out a surfboard in the middle. MB throws them in for free with all boats. So I am guessing Tige will charge $2,000 for a set of these.
              We don't even use the surfboard part any more because when you do, the surfboard removes all tension from the lower wakeboard. They just don't work right on the MB. Partly I think it's because the angle of the rack is not steep enough. I'd be interested to see what Samson comes up with.
