Goofy Side WakeSurf!
    Hey guys/girls of the Tige world!!!
    I am looking for all and any advice regarding my goffy side wakesurf. My wife and i currently own a 2012 RZR with the split front bow ballast. My wife rides regular(yeah right, haha) side and I on the 'Goofy' side. We usually don't have more than another peep or two and setup the ballast setting and wedge moreless the same, albeit we have 50lbs difference in weight. My dilema is that she has an amazing long clean crisp massive wake, my side is washed out and frothy with wash appearing to start with the swim platform and pumping up at me! We have adjusted with trying different things such as the split ballast levels, speed, and taps...
    Any and all advice wouls be much appreciated there Tige community!
    Cheers,
    James
    I've got a 2012 RZR with stock surf ballast set up (1600 lbs total). It has the single 400 sac in the bow. Like you, I ride goofy, and my wife rides regular (we also have one kid who rides goofy and the other who rides regular), so we switch sides frequently. We've been able to generate a really nice surf wave on both sides. Our set up is pretty simple: 100% ballast in the back corner where you are riding, 0% in the other back corner, 50-100% in the bow (for us that's 400 lbs), taps at 4, and speed at 10.4. Put any extra peeps you may have in the back corner where the rider is. If you have more people in the back corner, then you can put more weight up front. That should help make the wave a little longer. This weekend, I had two 200+ lbs guys in the back corner, so I put 100% in the bow. But if you don't have that extra weight in the back, you can do a little less weight in the bow. Hope it helps!
