I have that mesh seat that is no longer available but was really popular for several years. I really like it for the most part, but it has one problem that has always been there and is now getting much worse: It won't hold its front-to-back position adjustment.
The designers (not Tige, they buy it from someone - perhaps Attwood?) did a terrible job with the F-t-R adjustment. Instead of a simple, reliable straight shaft, the locking knob passes through u-joint like assemblies. These lock to the shafts using set screws, but the shafts are not D-shafts so there's really nothing for the set screws to lock into. Therefore the shafts rotate instead of transferring the torque to the actual locking piece. I've tightened them, I've applied LocTite, etc. and they still move. Next thing to do is grind a flat onto the shafts.
I haven't examined the actual locking mechanism all that closely yet, but I believe it's just a shaft binding against a flat metal surface. No real "locking" in a setup like that, it depends entirely on friction to hold. And it's not holding.
Anyone else experience this? Have you worked out a fix? If not, and if I solve it, I will post the results.
