Caution light next to engine light
    I'm getting the caution light on my dash next to my check engine light. It is flashing once. I just had the 25hr service done yesterday on my 2012 RZR. Anyone know what this means?
    Did the dealer mess with any (2) knock sensors on the engine block or any engine connetions? May have to have the dealer connect the laptop for a computer reading.
    Your maint manual talks about the red and orange warning lights.
    Good luck.
    Nick
    Dayton, Ohio
      I have a 2012 RZR also and the light has come on several times. I called Tige when it first came on to see if it was ok to continue to use the boat, they said the red triangle light was for emissions only and it was safe to use.
      The dealer had PCM look at it when it was in for the 20 hour service, I'm not sure what they did, but the light started to come back on again about a month later.
      Im bringing it back to the dealer tomorrow and PCM is coming out again to look at it.
      Marc
        what engine do you have?
          PCM 343
