how to surf???
This is our 2007 24ve, 3 people in boat. Enzo Ballast maybe 1/2 to 3/4 full on goofy side. Speed was 10.4, TAPS @ 3 I am riding my Inland Surfer Squirt which is faster but less forgiving and buoyant than my Inland Surfer Blue Lake.
Notice when I stand up or get my weight on back foot how I slow down, but when I crouch and put palms down I start accelerating. Find the balance. Also surf@ the base of the wave or at the slight downhill of the wave--not the top--that is where you get the push.
Ragboy posted how to 'pump' the board to re-catch a wave which I did well the first time, not so well the 2nd time. the dog-paddling is optional....
When you are learning it's good to hang onto the rope for a long time--slack means you are surfing, and if/when you lose the wave, pull yourself back into it.
Originally posted by Fire_medic View PostIve been using the broadcast board for peed I found the wake looks best at 9.5 it splashes over if I go faster and I havent screwed with the taps setting yet. Im going to get the 900lbs sumo sac and plumb it in the enzo sac is just too pricey the 900 with the 2 540s should be enough I hope. Has anyone delt with this wakemakers.com??
The Fly High Jumbo Surf will net you about 900 lbs and is only $10 more in retail price. This sac fits good in the 22V and 24V locker. Its a popular sac thats we sell a lot of. It will fill nearly to the top of the locker, placing the weight further back.
Stacking a sac on top of a plumbed-in sac is ok, just watch that you do not break a fitting. It will also tend to push out some of the water in the bottom sac. Just keep that in mind.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostThe 50x22x22 Sumo sac, based on its dimensions and the size of the locker, would probably net you about 800lbs.
Originally posted by EAHinsch View PostHey everyone,
I just purchased a 2007 24Ve that has two 400 lb sac's in the rear lockers and two 200 lb sacs in the forward storage areas. The previous owner who was much smaller than I surfed a very small skim board and had no issues. I have nearly mastered getting up and I have been trying relentlessly to throw the rope and can not do it. I have a 5'6" Fish and a older Liquid Force 5'4" Inland Surfer. I am 6'6" and 285 lbs. At this point I think it is the board since I have tried every wake position and many board positions. What are everyone's thoughts? I am considering the Hyperlite 5'11" Landlock Board......2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
