Faria Gauges
    Faria Gauges
    Hello, I am a new owner of a 2002 21v riders.
    I am looking for information and parts on the Gauges. I need replacement bulbs and I am looking for a matching clock to fill the hole where they installed a blank. My biggest concern is, I can not get the speedo or tach to light up at all and there is no obvious bulbs to replace. I don't even know what color they are. Half my Gauges are white and half red and it drives me crazy. Any information would be great!!!!!
    Thanks..
    It is hard to read but you need to get the artwork # of the gauge and then contact faria. They will give you a part # which you will then order by phone through west marine special orders ( faria will give the #). Once ordered faria will produce a matching custom gauge. I went through this for a volt gauge. It matched perfectly and only cost $38 but the whole process took a very long time. You may want to try through your dealer to make it easier.
      if the gauges that you are talking about have the up and down arrows and the little lcd screen. You just push the up arrow to get them to light up. It's kind of stupid it's not tied into the dash lights and it took me forever to figure it out. It takes about 4 or 5 pushes of the up to make it light up fully.
        Thanks guys!!! I would like to put a clock in the dummy hole so I won't mind the wait to make it all match. Im assuming mine are the same, I did not try the up down arrow. It's is a little silly they don't go on with the rest but I guess I can live with it. . Do you recall if the tach and spedo lights are white or red? I'm on a trip and need to order replacements for the remaing gauges for a trip as soon as I get back.
          What he said! Lights are red. If you do need tech help or repairs, call Faria, they are good to work with.
            My bad...... Didn't see an answer for red or white On bobbyskys post but thanks....now I can order........ Problem solved.
