How many of you guys have relocated there taps switch out of the throttle handle and into the dash? Im thinking about doing this to avoid having a short in the wires again. Any input or pics would be great.
relocate taps switch to dash?
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I have not done that, haven't heard of it really.
But my X45 had the trim tab switch on the dash and I found it painful compared to how my Tige was. I much preferred it on the throttle, because I could easily adjust throttle and TAPS at the same time. Usually an adjustment in one, requires and adjustment in the other, so having to leave the throttle to do TAPS was so unnatural to me.Be excellent to one another.
Originally posted by talltigeguy View PostI have not done that, haven't heard of it really.
Originally posted by goose69 View PostI did it two years ago. If you have perfect pass no need to have it on the throttle. Moved after I fixed the wires the second time.
If it is anything like my 2001, The center pivot of the throttle is hollow and the wire just goes through. It's not integrated into the throttle assy at all. Just clip the wires leaving a long pig tail at the switch and pull it through. The throttle assy is easy to remove just make sure the cable adjustments are correct or else the throttle will be super hard to operate.
