Onboard charger help
    Just purchased a NOCO 4 bank onboard charger for my 2006 22v. Couple questions
    Where is the best location or where have you installed yours..pics please
    I don't want to use the battery compartment door/panel
    Has anyone installed a Marinco Connect Charge Inlet
    If so anything that would help...where to cut hole...where to avoid...etc
    Just looking for any info that would help the install as I dont want to mess it up
    Thanks
    i mounted mine (NOCO 2 bank) to the board that's glassed in across the back. was a bit of a PITA bc it's at about a 45 and it's tight working but it's in there. I've got it to the port side of center a wee bit. No pics as I'm about 1000 miles from my boat right now. Haven't done the charge inlet, I just pop open the back locker and run an extension cord in...thought about it, but I'm lazy.
      that and don't you need to cut the plug off the charger and wire it directly to the back side of that? Or is that one just hollow so that you just run the wire through?
        It is the one you cut the wire and basically rewire....I will prob just run the ext cord
