OK I have done my research on the boards and had everything printed off ready to go. the How to was great and should have made this job a simple one.
Not sure if I did something wrong or if my boat is an anomaly.
I for the life of me could not get the new cable ran through the hull. I think it comes down to the size of my gas tank. It is a 48 Gallon Tank that runs a good ways past the hole under the drivers compartment where the cable is run through. This caused the angle to be impossible to get past the tank.
Anyone else ran into this problem? I don't know if this tank was the in the early model change only as I don't see 48 listed anywhere except the RZ4 of 2007.
My resolve was to make the hole under the driver compartment larger to get the angle where I could get the cable through the area.
