Took the boat out the other day and taps seemed to work ok other than being backwards. So today was going to switch the wiring and wanted to check it before I did anything and now gauge is not working and when checking the ram it only pulls in and will not extend out? I unhooked the mount to the taps plate to play around with it and I can unscrew the ram by hand that mounts to the plate and it extends but will not work under its own power. Anybody know why? Its an electric lenco unit.
taps only working one way?
Originally posted by topaz surfer View Post...will not work under its own power. Anybody know why?
Originally posted by Ruger761 View PostCan you hear your pump kicking on each direction? If the pumps only coming on one direction its a relay issue. The pumps are typically located, depending on boat, either under the helm, or under the glove box. It will have a carpet covered cover over it.You'll get your chance, smart guy.
Originally posted by Ruger761 View PostHmm dont know anything on those. Just finished fixing 2 hydraulic versions one was bad relay the other was a rewire and relays.
Sorry Topaz. Did you call Rick down at Custom Boat? He might have some ideas. You might also PM Boatwakes. He is pretty knowledgeable.You'll get your chance, smart guy.
