I couldn't agree more that when spending any of your hard earned money on anything you should get what you purchased in perfect order. We do strive to accomplish this, the vast majority of boats have few if any problems. I know PCM has put a fix in place on the manifold issue and it was the result of a bad casting that only surfaced after hours were put on the boats running their engines on the dynos did not surface the problems and even our lake test did not surface them, it is unfortunate that you the customer has to be inconvienced by this and that it lessens your enjoyment of your boat. We are moving as quickly as possible to get everyone on the water. This issue is not unique to Tige but all PCM 6.0 customers were affected. As to the ballast leaks those should never have left the factory and I am looking into our QC process to see how this happened, We will replace your graphics at your convience. There is nothing more important to us than having satisfied customers if your dealer is to far away or inconvient I will send a factory Tec. to your boat and fix your issues.
The improvments over that several years have been because we listen even if there is not a direct reply you can besure this forum is monitored daily.
Thanks for your support.
Rick Correll
Rick Correll
