Hello everyone , new here to the forum , and figured I could find the best answers here about these boats. I have an 08 tige' 22ve. Took the boat out for the first time this year, started fine, idled over to the dock, once everything was loaded , we went to take off, the boat would not come off idle no matter where I pushed the throttle. Anyone have any ideas I can try? Also this has the fly by wire . Thanks
08 tige ve throttle issue
Originally posted by bdas70 View PostHello everyone , new here to the forum , and figured I could find the best answers here about these boats. I have an 08 tige' 22ve. Took the boat out for the first time this year, started fine, idled over to the dock, once everything was loaded , we went to take off, the boat would not come off idle no matter where I pushed the throttle. Anyone have any ideas I can try? Also this has the fly by wire . Thanks
Did you get an alarm or just no throttle up?
On common cause is to leave a knock sensor disconnected during winterization. This will put the ECM into limp mode and restrict throttle-up, but there is typically an alarm also.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Check battery connections and charge both batteries. They way they are wired if the batteries are not both fully charged and the voltages are to far apart it will throw a code 81 and the throttle goes dead. Its a prettycommon issue. The best fix is rewiring the throttle control module to the same battery as the ECM. But charging both batteries should get you back up and running.
Yes, I had the same problem with my 2010 Z1 this spring. I had a surgeing problem with the boat as it would slow down and speed up at low RPMs, @800. It would surge about 200rpm up and down. The computer was sent out over the winter to be reprogramed to correct the problem. When I went to use the boat for the first time this spring it would only idle no mattter how far i advanced the throttle. The computer was sent back again to PCM to be reprogramed and works fine now. Your computer may need to be reprogramed.
