Custom Surf Sacs Tigé RZR ( Group Buy)
    Custom Surf Sacs Tigé RZR (Group Buy)
    I am looking at putting together a group buy of custom surf sacs that I have been developing with the help of Michael Sims from Mikes Liquid Audio (chpthil). * This is a direct plug and play surf sac swop for the Tigé RZR with the factory surf ballast system. * These custom sacs are built by FlyHigh, with the proper spacing for all the factory hook ups. *The custom sacs fit the whole back locker, under the back seat, and under the side storage locker, and water capacity is approximately *900-950lb's. *There are individual sacs developed for both regular and goofy foot. *The deal is that we need a minimum order of 5 sacs for each regular and goofy to get the pricing down to $570.00 each, plus 4 FlyHigh to Tigé hose fittings, plus shipping.
    Also we have been talking, that you can change the front/bow single sac for 2 v-drive locker sacs. Approximately 350-400lb's of water each. * With some relatively simple re plumbing of the single ballast vent to 2 vents, and just making the program change to the pro ballast from the surf ballast. *You will have complete control of fill and drain - left (regular) or right (goofy) from the Tigé Touch.
    Please PM if you have any questions.
    Cheers
    I wonder if they would work in a RZ2?
      Z3 as well??
        Originally posted by ecutter View Post
        Z3 as well??
        No because of the port locations as slightly different on the RZR/R20. After looking at the measurements, we decided to just do it as its own design
        We already have an RZ2 and RZ4/Z3 sac designed. I keep the RZ2 sacs in stock and just need to order one for those that want the RZ4/Z3 sac.
          These custom surf sacs are developed to fit the spacing and measurements of the RZR. The port spacing through the floor to the hard tanks, and the location of these line is different than any other Tige boat. Plus the size of the rear locker is smaller than a RZ2. The custom bags for a RZ2 will fit in the RZR, BUT the ports are not in the right locations for a RZR and that will put a lot of unneeded stress and wieght on the ports and the bag. Also the goofy foot custom bag for the RZR is longer than the one for the pre 2012 RZ2. The pre 2012 RZ2 had a cooler in the side locker, limiting the ballast space. The RZR has the same cooler location as the new 2012 RZ2, in the front of the boat.
            How big are the Z3 bags IE: How much weight??
              I'm in for one of each. What are we at? Let me know when we are at 5.
