Tow/Haul Mode?
    Tow/Haul Mode?
    Both my 2011 Supercrew F150 Ecoboost and my 2008 Escalade 6.2L (403hp) have a tow/haul mode. Both seem to tow my new RZR without struggling at all with the tow/haul off. The Escalade especially holds the gears for a really long time in tow/haul mode.
    Am I causing a lot of stress on the tranny and/or torque convertor if I pull my boat with the tow/haul off?
    For the Denali,Not at all, just watch your tranmission temps. You will probably not find much difference in tow/haul and out. As for the Ford, I hope you bought the extended warranty
      I have a 2011 Escalade and a 2011 F-150 Platinum with the 5.4L - for the Escalade the only value I have found in tow mode is the ease on the brakes. The brakes seem a little soft and undersizes for 22" wheel number one and for towing 6000 lbs.+ of weight number two. I barely feel the boat behind me from a powertrain perspective.
      The tow mode on the F-150 actually works pretty well especially when descending. As far as the transmission goes I would agree you have nothing to worry about on the Escalade. For the Ford - well it is a Ford and if you are traveling up and down hills/tow alot it certainly does not extend the life of the tranny. You are way under the tow rating of the vehicle to begin with, so I would say it is probably not that big of a deal unless you tow up and down hills the majority of your travels.
        I have noticed with my Ford (2011 with Eccoboost) that it will not drop into 6th gear very often. Prefers to stay in 5th up to 65 MPH or so. I don't tow the boat any faster.
        I have had three F250's (1 x 7.3, 2 x 6.0) and one F350 6.4L, and although those trucks towed a lot heavier weight, I have been truly impressed with the towing ability of that 3.5L Eccoboost.
          You should be able to feel how the trans is doing. With tow/haul on the gear will hold longer before shifting and will also work as a brake to help slow down the vehicle and load. That is the way it is designed. Now if when not engaged the trans shifts up and down a lot or you feel the engine is bogging down then you should engage it.
          Glad to hear you drive and love your Fords.
          Wake Up or Stay On Shore!
            Your trans will run cooler in tow/haul. I always towed in tow/haul with half tons, but not so much in my Diesel- unless towing over 10k lbs
              HoustonShark, I have an 11' EB 4x4 3.73 gears. I rarely use tow/haul when towing around houston or to Texas Tige. When we go north to the Trinity or out west to Lake Travis I use it in the hills. We towed 3,000 miles last summer on a cross-country trip and I only used tow/haul mode in the mountains of Tenn. Va. and Pa. Mainly, tow/haul will let your engine rev higher before shifting and then also implements a trans brake when slowing. I drive fairly conservative for Hosuton when towing so the higher shifts don't seem to be needed in the flat lands. Then with the trans brake on in tow/haul mode, you also lose the coasting feature which helps with mpg's if you care about that?
              Friends don't let friends POWERTURN
