Im trying to break down the pro60 and pro80 and get the shells ready for paint. is there anything I need to be cautious of. I know the pro 80 grill has three screws and something else but I didnt want to break it.
taking apart wet sounds pro series. HELP
IIRC, you have a grill, speaker and then nose piece. All the screws should be visible. The grill and speaker will come out easy, but the nose piece (section between the speaker and main body of the pod) might be tough to get to separate. After that, you have the clamp and sire pass-thru to remove. If you hit a road block, give a holla, im in the shop all day working.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jrj701 View PostThis may be a dumb question, but do you have to remove the speaker internals to remove the pods from the Alpha z? I was thinking about painting mine as well but didn't see how to remove them.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Slight hijack here: What is involved in running new wires through an Alpha Z tower? Those wire holes behind the speaker mounts are so small I doubt a traditional fish tape would pass through them. My two unused speaker spots are prewired, but I've thought about pulling the speaker wire and replacing it with something else (such as coax for a camera, for example). I could pull the new wire with the old, but how is the original wire installed in the first place?
Originally posted by WABoating View PostSlight hijack here: What is involved in running new wires through an Alpha Z tower? Those wire holes behind the speaker mounts are so small I doubt a traditional fish tape would pass through them. My two unused speaker spots are prewired, but I've thought about pulling the speaker wire and replacing it with something else (such as coax for a camera, for example). I could pull the new wire with the old, but how is the original wire installed in the first place?
You are couple days late for pics, I just hung a pair of REV-8's and fished for LEDs for the REV and the Pro60's on a 2011 RZ2.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by WABoating View PostThanks for the details. "Breeze" gives me hope that it won't be a huge challenge if and when!Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
