Poseidon Flooring
    Originally posted by artvandelay View Post
    Keep in mind you'll want the surface to be smooth under the Poseidon: it is quite "squishy" so you can really feel any imperfections on your feet
    We had a penny under ours and i noticed it right away
    Canada got rid of pennys last year, so Canadian Tige owners won't have this problem.
    I too am excited to see this project.
    Please hurry.
      Originally posted by Duncan View Post
      Wicked always has such a distorted view of "gravy" as compared to us mere mortals ...
      lol
        Well, I do not know if I am going to do this. Under the carpet the fiberglass is unfinished. I know that you would not see it with the posiedon on top but I think it would be a little sticky, rough and hard to clean. I think the carpet would come up easily. I started to pull up on a corner piece and it came up with very little resistance. I might get a price for a guy to put a finish gel coat on it first.
          do it your self its simple
            I got a Poseidon floor on its way.. Ill throw up pics when it shows up!
              Me too.
                Originally posted by robert theisen View Post
                Me too.
                Wait till you see the graphic i rendered into mine :-)
                  You will love it!
                  We have had our mat for about 1.5 months and we absolutely love it. The floor is never wet since it doesn't hold water and has never been hot (even in the Texas heat). We do have the bimini up though. You can occasionally feel a hinge under your feet but I would not hesitate to order one again.
                    Im intrested in the poseiden flooring what kind of cost would I be looking at for an 22v? can I just lay it over the existing carpet?
                      Robert & Wicked
                      did you order from Tige or aftermarket?
                        So... was it white fiberglass underneath? Or raw glass with no gelcoat?
                          For a 2012 you have to order through the factory. I called Poseidon yesterday and confirmed this.
                            Directly from poseidon flooring.
                              I pulled up a bit of my carpet today and learned two things:
                              1) The surface under my carpet (except for the fuel tank hatch lid) appears to be raw fiberglass but without the exposed "chopper gun" fibers. It's got little pimply bumps on it. If it's like this across the entire surface I think I could live with it as is, covered with Poseidon flooring.
                              2) There is a height difference between the carpeted surface (above) and the smooth gelcoat surface walkway up in the bow (where the snap-in carpet goes). If I remove the carpet in main passenger compartment, I'm going to have a step there approaching a half inch in height. How is that normally handled when you get Poseidon from the factory? Do they not gelcoat the front section? Is it all one level surface? What about retrofits - how to you handle the elevation change?
                                I've done some more research on the DECKadence marine flooring (aka "Poseidon"). It's a roll product with a standard width of three feet. A very few colors are available in four and six feet, but mostly it's a 36 inch wide roll.
                                I took rough measurements in my 24Ve today and three feet wide isn't enough to give me a solid, unbroken piece of DECKadence. That begs the question: Can you (or they) seam this stuff, and if so, how? Will a seam have a different feel under your feet due to adhesives or stitching?
                                I tried to imagine some way to arrange separate pieces on the floor so the cuts would end up out of the way, or on logical sight lines, etc. But I just couldn't come up with a clean arrangement. There is an obvious division between the bow walkway and the main passenger floor area, but the passenger floor area itself is a problem - particularly when you consider the driver's footwell area.
                                Anyone ever seen this stuff arranged as multiple pieces butted up against each other on a floor? How well does that work out?
