Originally posted by Booms
View Post
Poseidon Flooring
Im considering tearing my stained up nasty old carpet out and recoating with Ultra Tuff Marine. Easy application, and I end up with a nice, soft to the footsies, pressure washable coating.
It's what I used on the houseboat deck.So this monkey walks into a bar...
Originally posted by Duncan View PostI saw reference on another review site to "about $30 a linear foot". So that looks to be the standard retail price. The dealer map shows sources all over the country.
I presume the Poseidon flooring from the factory does not have snaps or the like. I wonder how it does towing with no cover?
Originally posted by Duncan View PostExcellent.
Now I just have to wait for Booms to rip his carpet up and see how much of a mess it is
The only hiccup I see is the rear seat is screwed in by a piece of carpet covered plastic. See picture. It is similair to the what you see below and next to the port side speaker.
The walk through/bow carpet currently has snaps in it. I might keep the snaps in it just for added security or I remove them and seal the holes.
I will start this project on June 15th and will post pictures on my findings.
I also added the picture from the Poseidon website of the Platinum sample. It looks vary similar to what I am looking for.Last edited by Booms; 06-05-2012, 05:50 PM."You're rather attractive for a beautiful girl with a great body."
Originally posted by skippabcool View PostI wondered if the piece that comes up to access the fuel tank, etc.., would be different than the rest of the floor.
Can't wait to see what you come up with. My wife managed to take on a bunch of water and the boat and garage stink.
I think I will keep the carpet around that access panel to make sure it does not squeak or rub.
Other than that I think I am going to remove it.
This is one project I am excited to start. I hate that the carpet stinks all the time."You're rather attractive for a beautiful girl with a great body."
Originally posted by Booms View PostI am starting to think that if the fuel tank access panel is a different material who cares. No one will see it. The Poseidon carpet will be in 99% of the time and I will be the only one that knows what is under it.
We had a penny under ours and i noticed it right away
Originally posted by Booms View PostWait for me. I was hoping to see what you found!
Originally posted by Booms View PostI think I will keep the carpet around that access panel to make sure it does not squeak or rub.
I am REALLY looking forward to your project
I also added the picture from the Poseidon website of the Platinum sample. It looks vary similar to what I am looking for.www.1320diesel.com Home of the Fastest Diesels!
Originally posted by Booms View PostI just talked with Paul @ Poseidon and he is going to call Tige to make sure he has the correct dimensions/template. The 08 RZ2 floor looks very similiar to the Plantinum addition picture that is on their website. The only difference is I have a round pedistal style chair mount where the newer RZ2s have a squared off fiberglass base. PM me if you want the quote he gave me with a painted tige logo. It was a lot less then what I was expecting.
This is a go for me if the fiberglass below the carpet is not damaged. I can get the adhesvie off just hope it is white fiberglass underneath.
pull the carpet up.. Go buy a block of dry ice move it around on floor and use nice scrapper to remove glue should be really easy once frozen. Then sand your surface with a nice 220 grit DA sander. vaccum the mess. get some tac cloths and wipe area clean. THen but a nice layer of gel coat down. Then your gravy all super easywww.1320diesel.com Home of the Fastest Diesels!
