I much prefer ther white.
Black or White Wetsounds Tower Speakers
I like Chpthril's idea of 2 or 3 color combo as all black tower and speakers is too much black.But everyone likes something different so you should do what you like best.Just look at the different options so you don't have any regrets.Good Luck!I do all my own stunt work. hey ya'll watch dis.
Originally posted by chpthril View PostColor matched to the boat (is that lime?) or Tuxedo - black pod w/wht nose.
The boat is Sublime, Black, and Frost.
What is your thought with Tuxedo ( just all Black)?Last edited by Robbie Mac.; 02-05-2012, 04:35 PM.
What is your thought with Tuxedo ( just all Black)?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by bspot View PostAre the leds on all the time or can you switch them off?
Wetsounds has also said that there is/are LED light collers coming for the XS-65 and XS-650 boat speakers that are used in the hull of the boat.
Originally posted by Robbie Mac. View PostThere are four wires in the harness for the new Wetsounds Rev8's and Rev10's. Two for the speakers and two for the LED lights that are an option for those speakers. I don't know what Tige is running the wires to if anything ??? I was just going to run the speaker LED lighting to the white ancher light on the tower. It could just as easily be run down the tower to the switch pannel ( if your into running wires in the tower).
The in-boats rings are coming soon and the REV-8 and 10 rings are ready to go right now. Wet Sounds offer red, blue, white and RGB.
IIRC, the Alpha-Z tower is prewired for speakers, but a harness would need to be fished for LEDsLast edited by chpthril; 02-05-2012, 11:24 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostThe speaker and LED is wired separately. You need to run a 2 conductor for the single color or a 4 conductor for the RGB LEDs and then they will be switched with their own power source. Single color you can just switch and the RGB needs a controller.
The fixed clamp and Alpha mounts do not come pre-wired for LEDs, but its not hard. I just installed the rings and wired my REV-10's with RGB's today. For the TC-3 swivel, there is a 6-pin adapter that is needed.
Im about to order my rev 10s and wire them up but i don't recall my alpha z tower having been pre wired??? Are they all like this and should be?
